ONEX #54 Web Site
Date: 4-23-2012
Number of Hours: 4.00
Manual Reference: W14
Brief Description: Wing fold pin assy
Completed drilling the pivot hole and slotted holes in W17-08, wing fold handle. Painted the "flag" indicator of the handle with primer and white enamel paint. I'll add some red " barber pole" stripes later.
Updrilled the hole in W14-03, fwd fork assy, to #12 for a snug fit of the AN3 bolt.
Drilled witness holes in W14-04, aft pin assembly. The drawing has the dimension lines offset, but the hole should be 3/8" from the end of the hex. Also needed to remove powder coating from one of the pin ends.
Updrilled the hole in W14-05, main spar pin to #12.
Fitted components together to complete W14-01 L/R, wing fold handle assembly.
Layed out and drilled holes in W14-10 L/R, wing fold retaining pin. Before drilling according to the print, I checked the assy against the pilot holes on the skin. The print location for the rivet line is 5/16" from the edge of the assy. However, aligning the pin handle to the center of the slide slot, the rivet line should be closer to 3/16" from the edge of the assy. I used the skin pilot holes as a guide, centered the pin handle in the slot, and located the holes on the -10 assy.
Wing fold handle assy
Wing fold retaining pin
